Hylomar - NCRS Discussion Boards
Hylomar
  • Gary R.
    • April 1, 1989
    • 1806
    Hylomar
    Has anyone used Permatex Hylomar on gaskets? I've heard it's pretty good stuff but no one in my area heard of it.
  • Jim L.
    • September 30, 1979
    • 1817
    Re: Hylomar
    From my very limited experience with it:
    - it remains tacky forever, as claimed, so parts can be disassembled and reassembled many times
    - it also remains a slow oozing liquid forever. if you disassemble parts and leave them disassembled, the Hylomar will creep
    - it is claimed to be fuel resistant. maybe. ethanol enhanced fuel will clean it right off. can't say about fuel without ethanol.
    Jim
    • Ken G.
      • December 11, 2008
      • 98
      Re: Hylomar
      Gary, in my opinion it is the best, especially for oil and fuel fittings as it is very resistant and flexible. Seems to me that only people that race know about it for some reason.
      Ken
      • Michael W.
        • April 1, 1997
        • 4290
        Re: Hylomar
        It's wonderful stuff. I used it first in my early days in the aviation field when assembling and testing gas turbines. I always thought it strange that a product made under license from Rolls Royce was used on a P&W engine but there you are.
        It's since come in very handy on several cars and bikes where no other goop would quite seal the joint. Now I know why Rolls invented it.
        • Gary R.
          • April 1, 1989
          • 1806
          Re: Hylomar
          Where do you guys find it? I can get it online but the only fuel resistent product I can find locally is #3 Aviation Permatex. I want to try it on new intake gaskets to test it with an oil leakage/burning problem.
          • Jim L.
            • 1817
            Re: Hylomar
            ..... the only fuel resistent product I can find locally is #3 Aviation Permatex.
            What kind of fuel is #3 capable of resisting? I tried it with ethanol laced fuel and it wimped out.
            Jim
            • Dick W.
              • 10483
              Re: Hylomar
              The Brits were great at manufacturing machinery that had massive oil leaks weren't they? They had to invent something to plug the leaks.
              Dick Whittington
              • Gary R.
                • April 1, 1989
                • 1806
                Re: Hylomar
                Jim
                Jim,
                I can't really say, just going by the Permatex info online and what I can find in my local NAPA and other parts stores.
                • Dan M.
                  • March 6, 2009
                  • 157
                  Re: Hylomar
                  Gary
                  I work in the aircraft engine business (just up a few towns from you in CT) and this is used in many different engine models all the time in bearing compartments to help seal them. Like on threaded fasteners that screw into oil wetted areas. Good for large temperature extrremes. Doesn't totally harden. Doesn't put any bad stuff into the oil system. I have an old tube at home and use it for applications noted above when I run into them.
                  • Scott M.
                    • January 1, 1996
                    • 216
                    Re: Hylomar
                    Gary I am usually able to find Hylomar in the local autoparts stores and use it quite a bit. Started using it years ago for Porsche and VW rebuilds.
                    • Peter J.
                      • September 30, 1994
                      • 586
                      Re: Hylomar
                      Gary,
                      Our local NAPA carries it.
                      Pete
                      • Gary R.
                        • April 1, 1989
                        • 1806
                        Re: Hylomar
                        Thanks guys, seems like the consensus is it's a good product and may work out well for my testing on the intake.
                        I checked my local NAPA and they were clueless, of course they once told me that sold USA Spicer joints only to find they were imported off brand ones.
                        I'll order some online and see how it works out.
                        Thanks everyone.
                        Dan if you go to the Moroso show on 7/10 look me up in the swap meet area.
                        Gary
                        • Dan M.
                          • March 6, 2009
                          • 157
                          Re: Hylomar
                          Gary
                          I would except I am in Daytona that weekend. Going down for the July 4th races and to spend some time at our condo on the ocean. I do need to get your services on a few things I want to get rebuilt on my '68. I will get in touch with you!
                          • Gary R.
                            • April 1, 1989
                            • 1806
                            Re: Hylomar
                            Well I stopped at a few more parts stores, no one heard of this. Last stop was an old time small independent parts store- sure enough he had it on the shelf for $10. Sold! I noticed he sold Standard ignition parts too- something once common and now hard to locate on a local level. Nice to still see some parts stores around still, this was a Big A store.
                            • Mel H.
                              • November 22, 2010
                              • 92
                              Re: Hylomar
                              Bought some at Advance Auto Parts last month. $9 bucks for small tube. First time I tried it.. worked great on thermostate gasket where intake surface was a bit rough, also hoses, vacumn fittings, fuel line fittings.
                              Its blue in color and some seeps out of fittings to form a nice blue seal around the base of the fitting. Not exactly stock appearance.. but can just remove it you want.
