Fuel Pump - NCRS Discussion Boards
Fuel Pump
  • Don C.
    • July 31, 2005
    • 20
    Fuel Pump
    Fuel pump with these numbers 4657 and 230, Is this a corvette pump if so what year?
  • David L.
    • July 31, 1980
    • 3310
    Re: Fuel Pump
    Is there an "AC" casting on the top and bottom of the pump? Is the pump stamped "4657" with or without 2 additional letters on the flange? Is there a 2-digit casting (example: "64") in the hole near the outlet with anywhere from 1 to 12 radial line segments (like a clock)? Exactly where is the "230" stamping on the pump?
    Dave
    • Don C.
      • July 31, 2005
      • 20
      Re: Fuel Pump
      Will look at pump to night,
        • 43247
        Re: Fuel Pump
        Don-----
        AC type 4657 fuel pump, aka GM #5621665, is applicable to 1959-63 Corvettes as well as 64-65 Corvettes with 250 and 300 hp. It's also applicable to many 1958-66 passenger car applications including 283, 327, 348 and 409 engines.
        • Don C.
          • July 31, 2005
          • 20
          Re: Fuel Pump
          thank you for the info. pump does does not have ac stamped on it. pump is mounted on a 245hp. thanks again!
