69 Th400 Help - NCRS Discussion Boards
69 Th400 Help
  • Brad H.
    • January 27, 2009
    • 250
    69 Th400 Help
    Anyone have knowledge on where I might buy a 1969 TH400 Transmission and I'm hoping for recommendations for a good rebuilder.
    Thanks again,
    Brad
  • Gary R.
    • April 1, 1989
    • 1798
    Re: 69 Th400 Help
    Hi Brad,
    If your TH400 is original to the car it should have a rivetted tag on the outside with the VIN. I would recommend rebuilding it if it is the original one. Just about any quality transmission shop can rebuild it stock or modified.
    When I rebuilt my 72's TH400 I wanted it stronger then I really needed so I went with a 69 drum and 32 element 2nd clutch and the full B&M master kit. The only thing I don't like about it is the clunk I get in off idler use because of the new spring in the pump. Otherwise normal driving is the same but if I punch it then it will chirp 2nd & 3rd gear. I went with the FORD ATF too but don't think it's really necessary, I would have been fine the the GM ATF.
    • Brad H.
      • January 27, 2009
      • 250
      Re: 69 Th400 Help
      Gary,
      Unfortunately the transmission is the only major component not original to the car. It has no tag on it and has been rebuilt twice and still leaks. I don't believe the transmission is a 69 mode. I am hoping to find a 1969 build TH400 to have rebuilt.
      Thanks for the info,
      Brad
        • 43213
        Re: 69 Th400 Help
        Originally posted by Brad Hood (49930)
        Gary,
        Brad
        Brad------
        You might want to contact a Corvette salvage yard like Contemporary Corvette in Bristol, PA.
        By the way, the production codes found on the riveted-on sideplate for the 1969 Corvette THM 400 transmissions are as follows:
        300 hp engine= "CK"
        390 and 400 hp engines= "CL"
        435/430 engines= "CY" ( you won't be finding one of these)
        Last edited by Joe L.; June 8, 2011, 11:03 PM. Reason: add transmission code info; correct info
        • Brad H.
          • January 27, 2009
          • 250
          Re: 69 Th400 Help
          Thanks Joe,
          I will call them today. I really appreciate the code info!
          Brad
          • Don W.
            • September 30, 1997
            • 492
            Re: 69 Th400 Help
            Hi Joe...Is there any difference in the 3 transmissions, or is it just the letter codes? thanks...Don
              • 15597
              Re: 69 Th400 Help
              Some years back there was a Corvette Restorer story about the details of the CY transmission. IIRC a heavy walled case is among the features, but there is a longer list of springs and clutch packs that are different among the three transmissions.
                • 43213
                Re: 69 Th400 Help
                Don------
                There are internal differences between the 3 different codes. And, there are differences between the plethora of other codes used for THM 400's in other car models and these 3. Some of the differences are quite minor; others not so minor.
