Lower Control Arms - NCRS Discussion Boards
Lower Control Arms
  • Philip M.
    • February 1, 1989
    • 5
    Lower Control Arms
    Can anyone tell me what the tab on the rear of the lower control arm is for?It appears to be a small angle welded to the arm opposite the sway bar mount.The arms I have have nuts welded where the tab should be.
  • Timothy B.
    • April 30, 1983
    • 5202
    Re: Lower Control Arms
    Philip,
    I believe it's a stop for the steering arm in the full left/right lock position.
      • 43273
      Originally posted by Timothy Barbieri (6542)
      Philip,
      Timothy and Phillip------
      ...and it's the same for all 1963-77 lower control arms. However, it's not the same for 1978-82. Due to the optional 255-60-15 tire size used during these years, the steering arm stop changed very slightly in size and was used on all cars, not just those equipped with the larger tires.
