Need source for original pistons (396) - NCRS Discussion Boards
    • 43213
    Re: Need source for original pistons (396)
    Originally posted by Domenic Tallarita (51287)
    Dick,
    The pistons sets are matched weights but they don't match the factory weight which requires another engine balance.
    DOM
    DOM------
    Anyone that rebuilds an engine, including using all NOS internal engine parts, is nuts if they don't have it balanced. And, if this is done, it's a moot point whether the replacement pistons (or any other reciprocating parts) are the same weight as the originals.
      • 43213
      It was my understanding that Alcoa did the forging of the blanks for all the manufacturers of those pistons.
      Dick-----
      I would not be surprised, at all, if that was the case. When it comes to aluminum forging, it's pretty much a "big guy" kind of operation.
      I believe the C4 forged aluminum suspension components were forged by either Alcoa or Kaiser. I expect the C5 and C6 forged suspension components are done by Alcoa.
      • Clem Z.
        • January 1, 2006
        • 9427
        #18
        DOM------
        YES and you get a much smoother running engine because the factory balance had a broader spread than a good auto machine shop balance. good shops balance to within the weight of a dollar bill !!!!
          • 43213
          #19
          clem-----
          YUP!
          • Domenic T.
            • January 29, 2010
            • 2452
            #20
            DOM------
            Joe,
            I was talking about the old days, but there are a lot of NUTS people that do this every day that are smart enough to use the weights that the manufacturer uses.
            I balance EVERYTHING and sometimes it is on and off the scale and back in or on.
            When you bur a new car it is NOT personally balanced as you know. If you tear it down and install the same weights you assume the factory balance.
            If you take a virgin engine down that ran smooth and rebuild it with the same weight it will still run smooth.
            When I twisted a wrench for a chevy dealer back in the 70's virgin rebuilds were not ballanced because the weight of the parts (crank/pistons/rods/and pins) were controlled at production as to save space and reduce error which makes perfect production sence.
            The race guys did ballance but my grand mothers car wasn't.
            DOM
            • Domenic T.
              • January 29, 2010
              • 2452
              #21
              Clem,
              It was the weight of a 100 dollar bill.
              DOM
              • Clem Z.
                • January 1, 2006
                • 9427
                #22
                Clem,
                DOM
                i was posting about my days i forgot about allowing for inflation.
                  We built the Viper V-10 from the bare castings up, in-house, at the Viper assembly plant; the piston/pin/rod/rings came from Mahle as an assembly - we just installed the rod bearing inserts. The forged crank (fully-machined on all surfaces) was pre-balanced based on the specified rotating/reciprocating weight of the Mahle piston/rod assembly plus the bearing inserts. No additional balancing of the rotating assembly was done during engine assembly. Part of the daily ISO-9000 conformance audit procedure was weighing the Mahle assembly.
