Alternator bracket bolt markings on 70 sb - NCRS Discussion Boards
  • Steve D.
    • May 16, 2011
    • 106
    What are the correct bolt headmarks for the upper and lower brackets?
    • 15569
    Re: Alternator bracket bolt markings on 70 sb
    Upper is usually WB, but sometimes SBC, always grade 5 (three lines) with a dark (some would say black) split lockwasher and a thicker and larger diameter than normal washer. Hex head faces the rear of the car.
    Someone else can shoot at the bottom.
