fuelie filter - NCRS Discussion Boards
fuelie filter
  • Jack A.
    • March 1, 2001
    • 129
    fuelie filter
    I have a 61 315 HP fuelie I am almost fiished restoring. I have installed the Air filter ductwork and am now ready for the filter. I have found the air filter elements in several of the catalogues. On top of the fact that they are very expensive they appear very stock. What I was wondering is if there was a high performance filter like a K & N that was available that any of you guys may be aware of, or at the least a normal supplier that may handle a more resonably priced one. I will drive this car and don't look forward to spending about $100 each time I change the filter, which I will do often.
    Thanks as always,
    Jack Alexander 35730
  • Jerry C.
    • November 1, 1995
    • 741
    Re: fuelie filter
    Corvette Central shows #351001 1959-1961 filter for $7.95 if you have the correct filter housing.
    • Doug F.
      • November 1, 1983
      • 322
      Re: fuelie filter
      I believe the K&N # is E 1935
      • Bruce B.
        • May 31, 1996
        • 2930
        Re: fuelie filter
        Jerry,
        The CC #351001 is the fuel filter cartridge.
        I believe Jack is referring to the air filter.
        • Jim L.
          • September 30, 1979
          • 1817
          Re: fuelie filter
          That is correct. The E1935 filter looks like this:
          Here is a link to more information:
          Shop replacement K&N air filters, cold air intakes, oil filters, cabin filters, home air filters, and other high performance parts. Factory direct from the official K&N website.
          Jim
          • Jack A.
            • March 1, 2001
            • 129
            Re: fuelie filter
            Thanks to all of you. As usual the correct answer in no time. I am just putting the finishing touches on a 3 1/2 year ground up on my 61 fuelie and I could not have done it without all of you. More diferent people on this board have lent their expertise to this project that I could possibly name. I look forward to helping others in the future through this fine provision.
            Warm Regards,
            PS: I got it through Advanced Auto for $55 next day delivery
              • 15706
              Re: fuelie filter
              Sorry I didn't see this before, but K&N filters are overpriced junk. They filter poorly and don't flow any better than a same size quality cellulose filter.
              If you don't want to dirt hone your cylinder bores, take it back and search for a name brand cellulose filter.
              There's lots of discussion on this issue in the archives.
              • John D.
                • December 1, 1979
                • 5507
                Re: fuelie filter
                The K&N filter for your 58 to early 62 is not the worlds answer as Duke mentioned.
                But personally I am not aware of a good paper filter like the original?
                There used to be a good repro but I don't believe it's available anymore.
                Personally I prefer the paper style filters in all of my vehicles. JD
                P.S. No I do not know where a fellow can find an original filter. I probably get a call or two a month with that question.
