Radio Clicks when shifting - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    Re: Radio Clicks when shifting
    Sorry it took so long to check back. I unplugged the TCS switch on the trans side cover and the clicking stopped.
    Does this mean the switch a is bad or that there is an open circuit. I do not have the jumper wire between the harness and the temp switch in the head.
    Thanks. You guys are amazing.
    • Paul O.
      • August 31, 1990
      • 1716
      Bill
      I would suggest checking the grounding of your radio and the center bezel and the CEC system as a first step in troubleshooting the clicking sound. I do not recall a capacitor in the radio circuit but there could be one. The clicking you are hearing is most likely being caused by the CEC sending a signal though ether your antenna or the radio circuitry then to the speakers when power is applied or removed from the CEC.
      Check to make sure the relay has a good ground just remembered on a 71 the relays have a separate ground at the relay mount do not remember where a 70 relay is or the ground for it is located.
      Paul 18046
      • Bill L.
        • February 1, 2004
        • 1403
        Thought I would post a follow up.
        I went through all the grounds again. What I found is that I left off one of the two star washers where the ant. grounds to the frame. I had the one on the outside but not the one between the ground strap and the frame.
        I put the second washer on and bingo, problem solved.
        Thanks for all the help.
        Bill
        • Bruce B.
          • May 31, 1996
          • 2930
          Paul,
          For us guys with C1s, what is a TCS and a CEC switch?
          Can I put them on my 57??
          I thought AM radio's were supposed to click most of the time...
          • Paul O.
            • August 31, 1990
            • 1716
            Bruce
            TCS stands for Transmission Controlled Spark.
            CEC stands for Combined Emissions Control.
            This would be toooo! technical for a C1 person to deal with please leave this alone. It would take to long to explain.
            AM radio that is only used in a C3 if the FM has failed and everyone knows that never happens.
            Just remember Real Sports Cars do not have Trunks.
            Paul 18046
