2 questions on transmission spark cotrol system - NCRS Discussion Boards
  • Steve D.
    • May 16, 2011
    • 106
    Okay,
    my 70 350/300 has most of the system missing. I have located all the parts to be purchased except for 2. The hard tube. If I cannot locate one maybe I can have one bent. What is the tube thickness? 1/4 inch?
    I also the the relay that is part of the system. Any suggestions on where to locate either or both for purchase?
  • Pat M.
    • April 1, 2006
    • 1579
    Re: 2 questions on transmission spark cotrol system
    Steve you can get the relay from Paragon or Ebay:
    https://www.paragoncorvette.com/p-36...nce-delay.aspx
      • 15615
      I think you will have to bend the tube, but one of the board participants posted about this, with a measured diagram in the past. Perhaps that member is willing to make one for you. Try SEARCH
      • Duane D.
        • April 15, 2009
        • 67
        Steve, for the vacuum tube dimensions, do the following:
        - Go to 70corvetteregistry.org
        - Research and resources
        - Photographic Library
        - Mechanical
        - Vacuum advance tube
        Good luck, Duane Dunlap
