1967 grill screws - NCRS Discussion Boards
1967 grill screws
  • Timothy B.
    • April 30, 1983
    • 5186
    1967 grill screws
    Can someone tell me or post a picture of the correct screws that are used to attach the 1967 grill to inner fender and top panel.
    Thanks in advance, Tim
  • Rich P.
    • January 12, 2009
    • 1361
    Re: 1967 grill screws
    2 long screws for top and bottom center attaching points, 4 short screws for grill bracket to fender skirt attaching points and hex bolt for grill rod to header bar. These are originals.
    Rich
    • Henry S.
      • April 30, 2005
      • 816
      Rich
      Rich, Is the "D" headmark the only one or most common for that bolt? Shooter
      • Rich P.
        • January 12, 2009
        • 1361
        Henry,
        the D is the most common. Others I have seen are anchor, RBW, E and a few more. If I remember correctly the JM calls out for the D headmarking.
        Rich
        • Timothy B.
          • April 30, 1983
          • 5186
          Thanks Rich, I appreciate the pictures. The phillips screws with washers almost look like door screws. I need to check my stash, are all seven of these screws 1/4" thread?
          • Henry S.
            • April 30, 2005
            • 816
            Henry,
            Rich
            Thanks Rich.
            • Scott S.
              • September 11, 2009
              • 1961
              Tim,
              I believe the six Screws with attached washers are 1/4-20 x 5/8". If I have the correct Grille center rod upper Screw, it measures 1/4-14 x 3/4". It looks just like the one Rich posted, with the "D" headmark, no grade lines, indented hex washer face.
              • Timothy B.
                • April 30, 1983
                • 5186
                Thanks Scott,
                So would this grill screw have a 3/8"or 7/16" hex (wrench size) across the flats? I think I have one with E headmarking but need to double check the thread and hex size.
                • Scott S.
                  • 1961
                  Thanks Scott,
                  Tim,
                  The Grill rod screw that I have takes a 3/8" wrench size. If Rich sees these recent posts, hopefully he will be able to confirm (or correct) the measurements I have posted, to make sure we're all on the same (correct) page. I just recently found what I think is my original grill rod center screw (mentioned above, "D" headmark, 1/4-14 x 3/4"), it was mixed in with the bag of fasteners from my C60 battery access panel.
                  • Henry S.
                    • April 30, 2005
                    • 816
                    Got to wondering about mine. I was pretty sure I had one like Rich posted with a "D" or "E" headmark because I remembered seeing it in my "bolt bag" when I had them replated. Below is what I found. It looks similar to a hood support bolt but I don't they are as long. Any idea where this one goes? Thanks.
                    • Henry S.
                      • April 30, 2005
                      • 816
                      Here are the "E" and "D" headmark bolts I thought was used on the grill bracket but they both have grade marks. And as Steve pointed out, originals didn't have them.
                      • Timothy B.
                        • April 30, 1983
                        • 5186
                        My 67 still has it's original in that location and I can't see a headmarking but otherwise it looks exactly like Rich's photo, I will take a digital pic and post.
                        The flat washer is fixed and attached to the bolt head.
                        • Scott S.
                          • 1961
                          Henry,
                          The bolt in your photo (post #10) looks like it's 5/16-18 x 1-1/8" with a 3/4" O.D. attached washer, bolt head measuring 1/2" across the flats. Is that correct?
                          Edit: I meant 1-1/16" on the bolt length (not 1-1/8"), measured from underside of bolt head to the pointed tip.
                          • Scott S.
                            • 1961
                            Tim, if possible could you check the wrench size? I thought it was supposed to be a 3/8" across-the-flats bolt, and that's what mine is, but I read in another Thread that it should be 7/16".
                            • Timothy B.
                              • April 30, 1983
                              • 5186
                              Scott, That bolt head is 3/8" across the flats, I will get a picture and post.
