All through the winter the engine turned over fine, but it just wouldn't start. So I called my mechanic about 6 weeks ago and made an appointment, and also set up a tow. To make it easier on him, and to make sure that the distributor ignition shielding didn't get damaged, I removed it before taking it in. I tried to start it once more before the tow arrived, and the engine started fine. I took it to the mechanic anyway, and had him take a look. At that time I didn't associate the removal of the shielding with the no start problem.
He adjusted the carburetor, verified that the ignition system was functioning properly and I brought it home. I took it out three weekends in a row and the engine started without issue. It was time to get it ready for a local show, so I reinstalled the shielding on the morning of the show. I then tried to start it so that I could get it out of the garage to clean it up, and it wouldn't start. It turned over just fine, but it wouldn't fire up. During the next two weeks I tried to start it numerous times, without success.
I made another appointment with the mechanic and the towing company for tomorrow morning, and just now removed the ignition shielding. I decided to try to start it and it kicked right over.
So the question is, is it possible that the shielding could be grounding some component or causing some other issue, has anyone else ever had a a problem like this, or do you think that this might just be a coincidence and that there is some other problem?
Added: The ignition shielding is the '70 early type box shielding.
