1967 powerglide - NCRS Discussion Boards
1967 powerglide
+ More Options
Posts
  • Peggy S.
    • June 28, 2009
    • 1
    1967 powerglide
    Trying to adjust the kick down linkage on my trans. The aim is to confusing for me, any helpful hints?
    Bill S****
  • Russ S.
    • April 30, 1982
    • 2163
    Re: 1967 powerglide
    Bill, I will take a stab at it. In the 66 chassis service manual under throttle valve linkage adjustment (I am assumeing that is GM's name for the kick down) it says: With accelerator pedal depressed, bell crank on L-4 and L-6 models or carburator lever on V8 models must be at wide open throttle position.
    Dash lever must be 1/64-1/16 inch off lever stop and transmission lever must be against transmission internal stop. Hope this helps.
      Re: 1967 powerglide
      Bill S****
      Bill -
      There's a simplified kickdown linkage adjustment procedure on page 7-30 of the 1967 Chassis Service Manual.
