69 tunnel heat shield - NCRS Discussion Boards
  • Brad S.
    • July 31, 2005
    • 227
    I' doing under body stuff getting ready for body drop but not sure about the positioning of the foam bellhousing heat shield? Does anyone know where it is supposed to be from front to rear? Thanks Brad
    • 15606
    Re: 69 tunnel heat shield
    When I had my transmission out, I put the new seal on the marks that were on the bell housing from the original seal. That gave me the exact location for my Corvette.
      • 6948
      Brad, I would think the position of the factory retainers would not let you position more than a few inchs either way.
        • 15606
        Foam bell housing collar, Ed -- not the tunnel heat shield with the aluminum foil outer cover.
          • 3416
          Hi Brad,
          On my 71 sb the front of the collar was about even with the heavy joint in the fiberglass between the firewall and the underbody.
          • Brad S.
            • July 31, 2005
            • 227
            Alan, was it centered on the seam or in front or to the rear of the seam? Thanks Brad
            • Lawrence M.
              • February 1, 1995
              • 404
              If this picture is big enough you should be able to see the collar.
              Larry
              2002 Z51 Convertible
              1969 L46 Convertible
                • 6948
                Missed that Terry, thanks
                • Brad S.
                  • July 31, 2005
                  • 227
                  Is this shield glued or just sandwiched between the tunnel and the bellhousing? The AIM doesn't call out any glue.
                    • 15606
                      • 3416
                      Hi Brad,
                      The front of the collar was about even with the seam, so I'd say the collar was to the rear of the seam.
                      On my 71 there wasn't any sign of glue.
                      • Brad S.
                        • July 31, 2005
                        • 227
                        Thanks Alan and Terry
