'66 fuel sending unit - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 7064
    Can anyone tell me if the fuel sending unit in the accompanying photo would be correct for '66 in terms of the insulator style and color (milky white) and the pin style of the electrical connectors?
    Gary
  • Russ S.
    • April 30, 1982
    • 2163
    Re: '66 fuel sending unit
    Gary, I believe mine in my 66 is original. It has that style pin with the second pin very similar style only smaller dia. than the other pin. My insulator is very different. It is thinner and sets below a hex nut. The stamping is the same as yours.
    • Gary B.
      • February 1, 1997
      • 7064
      Russ,
      Do you have a photo of the unit from your '66 that you could post?
      Gary
      • Peter J.
        • September 30, 1994
        • 586
        Gary
        Here is a picture of my original 66 unit. I will see if I have any better pictures as it is off being restored. The junk replacement units units look to be a fire hazard to me. I got a better replacement unit from a good vendor but my calibration is way off even with this more expensive unit so off to the restorer for the original that never gave me any trouble.
        Pete
        • Peter J.
          • 586
          Here is another picture I got from the internet a few years back when I was looking for an original.
          • Russ S.
            • April 30, 1982
            • 2163
            Gary, The two pis posted are what mine looks like. I will try getting a pic of mine also later. Since you asked the question I removed the gas tank from a customers 66 chassis that I am going to be restoreing. I can't say whether his is original or not but it is exactly like yours with the plastic nuts instead of the steel nuts.
            • Joe R.
              • July 31, 1976
              • 4552
              Gary,
              Yes, that unit is correct for 63-67 SB or BB. I have four of those exact units from 63-67 Corvettes. Everything on it is correct including the color of the insulators.
              JR
              • Gary B.
                • February 1, 1997
                • 7064
                Originally posted by Joe Ray (1011)
                Gary,
                JR
                JR,
                Are you saying the one I posted the image of is correct? Or the one Peter posted? Or both? Should the one I posted the image of have nuts next to the insulators? I think I can see about 1 thread or so, no more, next to the insulator, so it would be hard to have a nut thread on securely. Should there be a nut on each post and something compresses to allow more thread engagement?
                Gary
                • Scott S.
                  • September 11, 2009
                  • 1961
                  Gary
                  Gary,
                  The 1966 and 1967 AIMs show the same part number for the fuel sending unit, GM #6425827. My '65 AIM shows no part number (it's blank next to the part name), and 1968 used a different part number.
                  The sending unit I have is (I think) original to the '67 I'm working on. I had it restored a year or so ago, but I have not installed it yet. From what I can see, the one you show looks the same as mine, here are some before and after pictures to compare with yours.
                  Before:
                    Here's another original sender.
                    • Scott S.
                      • 1961
                      Here are the after pictures. As you will see, they changed the float.
                      • Joe R.
                        • July 31, 1976
                        • 4552
                        JR,
                        Gary
                        Gary,
                        You are reading much to much into this!!!!! First the image of your fuel sender is correct. The nut holds the studs in place. There is NO nut other than what you see. Those are studs and the wires have connectors that push on to those studs with a rubber boot covering the entire stud and insulator.
                        JR
                        • Gary B.
                          • February 1, 1997
                          • 7064
                          Gary,
                          JR
                          Thanks for the clarification. Since my sender has no nuts, I think the pins must be falling thru, which is why I can't see more exposed threads. I'll give the pins a gentle tug and see what happens.
                          Gary
                          • Russ S.
                            • April 30, 1982
                            • 2163
                            Originally posted by Scott Smith (50839)
                            Gary,
                            Before:
                            Scott, The one you show and the one Gary shows are not the same. Gary's has the white plastic nuts and yours are the steel nuts.
                            • Russ S.
                              • April 30, 1982
                              • 2163
                              JR,
                              Gary
                              Gary, Look closely again. Aren't the white plastic insulators actually threaded nuts? They are on one of the senders I have from a 66.
