Reverse lens question - NCRS Discussion Boards
  • Steve D.
    • May 16, 2011
    • 106
    The guide says that the guide lettering should be on the outside of the chrome circle on the stop/turn lens. But it does not mention the reverse lens at all. Is it the same?
  • R N.
    • May 31, 2002
    • 640
    Re: Reverse lens question
    Hi Steve,
    I beleive that to be true for the stop/turn lens and that the reverse lens has the writting in the inner circle.
    • Pat M.
      • April 1, 2006
      • 1580
      Originals I've seen have the numbers on the edge of the clear portion of the lens. The exact location of the numbers, relative to the red lens, can vary.
      Also, the glue attaching the clear portion is usually a little sloppily applied, in that, it protrudes out a bit. In the pic below the glue appears as a dark, rough line above the numbers where the clear lens meets the red.
      • R N.
        • May 31, 2002
        • 640
        Photos of my '70 stop/turn and reverse lens. Look at the middle photo and you can see the glue oozing out btween the clear lens that Pat mentions.
        • Don L.
          • August 31, 2005
          • 1005
          Pat, I'm having a little trouble picking up on the orientation of the photo in your post. Is the center lens (white) assembled so that the "GUIDE..." letters are upside down in the car position? I have one lens (red/outboard) that is assembled such that the "GUIDE..." letters are inverted vs the other /opposite lens.
          I hadn't seen this before and wondered if this was a random occurrence.
          Don Lowe
          NCRS #44382
          Carolinas Chapter
          • Pat M.
            • April 1, 2006
            • 1580
            Hi Don. The numbers in my picture are right-side-up... they are nearly at 12'oclock when looking from the back of the car. But, as I've said before, I've seen the back-up lens numbers at various locations relative to the outer red lens.
              • 3416
              Hi Don,
              On my 71 the lenses for the back-up lights have the word GUIDE at about the 10 o'clock position and you read it normally. The letters and numbers on the clear/white part of the lenses run from about 7 to 5 o'clock.
              PS: I haven't forgotten about the carpet picture.
              • Don L.
                • August 31, 2005
                • 1005
                This is interesting. I have 1 of 4 lenses that the "GUIDE..." lettering is 180* from where the rest are. I have looked, over the years, at others, trying to see if mine was an anomoly or if it was reassembled wrong by a PO. This thread is shedding some light on the issue. Thanks for posting!
                Don Lowe
                NCRS #44382
                Carolinas Chapter
