Battery Tender Recommendation? - NCRS Discussion Boards
  • James S.
    • June 22, 2008
    • 226
    What would you recommend that is highly dependable?
    Thanks in advance.
    Jim
  • Tom H.
    • December 1, 1993
    • 3440
    Re: Battery Tender Recommendation?
    Battery Minder Plus !
    BatteryMINDers' desulfating battery charger maintainers fully charge without ever overcharging, no matter how long they are left connected. Visit our website to browse our available products.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Gary B.
      • September 30, 1987
      • 305
      I have a couple of Shumachers and have had no problems.
      Available at most auto supply shops.
      Walmart is the cheapest.
      • R N.
        • May 31, 2002
        • 640
        I'm with Tom, I've got 7 of them, with the oldest one around 8-years old with no issues.
        • James S.
          • June 22, 2008
          • 226
          Thanks!
          JIM
          • Phil D.
            • January 17, 2008
            • 206
            Just avoid the Sears Diehard brand charger/maintainer. I had serious issues with multiple units I already posted about in another thread. If you are gonna leave your baby plugged into the wall unattended for days or weeks at a time, you want a unit you can trust won't boil your battery or catch your garage on fire. I returned my Sears units for a refund and bought Battery Tender brand instead.
            • Joe R.
              • May 31, 2006
              • 1822
              Originally posted by Tom Hendricks (23758)
              Hey Tom,
              I agree with you, that's the one to get! It's the only one that I know of that desulfates your battery.
              Joe
              • Tom L.
                • October 17, 2006
                • 1439
                Anyone have any experience with the Battery Butler advertized in the driveline by Lectric limited? I had an electrical problem in my house over the winter and my Battery Minder was a casualty along with several other electronic devices, not its fault though.
                • Paul S.
                  • April 6, 2010
                  • 148
                  I like the c-tek 3300--use one my 67 and another on my 06 911 (the Porsche branded version, thereof). You have to shop around the web for the best price--I've seen the price vary by as much as $40 higher from place to place. And it has the desulphation function which is a desireable feature to prolong battery life.
                    • 15625
                    Any battery maintainer with a desulphation feature is useful on ANY battery. I put my driver cars on one of my maintainers periodically just for this reason. I had to buy a new battery for the Z06 yesterday -- I got 3.5 years out of the AC Delco factory original battery (made by Exide, I believe) -- and I put the new battery on the maintainer for a couple of days just for S & G.
                    • Michael J.
                      • January 27, 2009
                      • 7161
                      This is a really interesting issue. I have had BatteryMINDer Plus for a few years, as there was a recommendation in the box of my Restoration Battery Delco Eye I bought. Then I purchased another battery for another of my cars from Antique Auto Battery (who claims to make the batteries supplied by Restoration Battery) and they said the Battery MINDer Plus only charges the top 1/3 of the battery and thus a battery on this will not last many years since it is not deeply charged as when you drive it frequently. They recommend the Odyssey or a good 10 amp automatic charger. Any opinions out there on this?
                      • Paul S.
                        • April 6, 2010
                        • 148
                        Interesting--I am not sure why (other than time to full charge) the recommendation for a 10 amp output. Looking at the spec sheet for my c-tek 3300 it has a max charging output of 3 amps and indicates 3-4 hours to charge a dead battery to 80%, at which point it starts tapering off the output and it will fully charge a battery (that's not "shot"), although I've never had a stone dead battery which wasn't shorted/spent to test that out.
                        I know that some lower amp output maintainers can maintain but not take a battery from near dead to full charge--example, before going to the c-tek's Porsche used a different model/brand that had a lower max charging output (something around 1.5 amps). When Porsche switched to the c-tek, being able to fully charge a battery was one of the differences cited (and for quite awhile, you could by either version from Porsche dealers).
                        I'm no expert, but I don't think (assuming you use the maintainer whenever the car is sitting between drives) you would need 10 amps output ever. So I certainly wouldn't be in a rush to replace a maintainer you have and are happy with.
                          • 11689
                          I suspect what they "may" mean is this -
                          if your battery is down below 10-10.5 volts, the Battery MINDer won't charge it. It will show that it's charging but the battery won't charge. However, if you swap on a "regular" 10A charger the battery will charge and you'll be on your way.
                          I had this happen last year on the 08, and the only Chevy service manager I trust told me that he has seen this. As long as you hook up the Battery MINDer when the battery level is good (or you don't lose power because it gets unplugged ) you will be fine. When this occurred I used my "regular" charger for a day then swapped back to my MINDer after that. This past winter it kept the battery in excellent charge.
                          Patrick
                            I've used the (Deltran) Battery Tender for many years on Delco replacement batteries, with great results. Both my '69 Z/28 and my '67 Corvette have Delco Professional Series #24-7YR batteries; the one in my Z/28 finally gave out last week (after 12 years), and the one in my Corvette is still going strong after 11 years.
                            Nice warranty on the Professional Series Delco batteries - full replacement (no pro-rate) up to 50 months, and pro-rate from 51 months to 7 years.
                            • Tom R.
                              • June 30, 1993
                              • 4100
                              I picked up a Schauer ChargeMaster CM1A that incorporates a "conditioner" mode...the desulfation feature for under $30.00. An additional feature was what appeared to be the longer cord.
                              Tom Russo
                              78 SA NCRS 5 Star Bowtie
                              78 Pace Car L82 M21
                              00 MY/TR/Conv
