Powerglide leaks - NCRS Discussion Boards
Powerglide leaks
  • Jorn J.
    • October 21, 2008
    • 142
    Powerglide leaks
    Hi
    I have just put on new seals in front and rear in my powerglide but it still leaks
    I have seen in Passenger Car Shop Manual on page 13-11 fig.20 that there are no seal between Pump and Cover! is that right?
    Could it be there it leaks?
    C1,1959.
    Regards Jorn
  • Peter V.
    • June 2, 2008
    • 116
    Re: Powerglide leaks
    Jorn,
    My '61 cast iron powerglide "seeps" fluid, probably a pint every two months. Seepage is worst when the car is parked and cold rather than during use. I have replaced every seal at least once and have not been able to completely stop the seepage. Wish I could, as I don't leak any other fluids.
    Knowledgable rebuilders won't even guarantee a dry cast iron PG.
    Keep an eye on the fluid and add a bit when required.
    • Jorn J.
      • October 21, 2008
      • 142
      Hi Peter
      I know they are leaking these Powerglides but its only a shaft that goes into a hole with this special sealing and I wonder why its so diff. to seal such system, i think; see my auto-lift it has also the same sealing"system" and its not leaking.
      You can't visit your friends without dripping oil on their driveway and so
      Its frustrating.
      regards Jorn
