C-1 Wheel Cylinders - NCRS Discussion Boards
C-1 Wheel Cylinders
  • Jerry C.
    • November 1, 1995
    • 741
    C-1 Wheel Cylinders
    Noticed 59 and 60 front wheel cylinders have a different part number, what is the difference? What are the correct numbers for front and rear for 59 and 60? Thanks in advance.
  • Mike E.
    • February 28, 1975
    • 5140
    Re: C-1 Wheel Cylinders
    649 for rears for all. 60-62 fronts (standard) are 528 and 529---58-59 are 821 and 822. The size of the bore changed, hence the part number changed. (and with the bore change, the percent of braking front/rear changed.) Part nos. are off the top of my head--sorry I can't give you the first 4 digits.)
    • Steven B.
      • June 30, 1982
      • 3997
      Mike, will the later ones improve braking on a '57?
      Thanks!
      Steve
      • Jim L.
        • September 30, 1979
        • 1816
        The larger, 1-3/16" front wheel cylinders will definitely improve the illusion that your '57 brakes will stop it.
        More seriously, yes, it's a worthwhile change and I recommend it. The effective pedal effort will be noticeably reduced.
        Jim
