Clutch Pedal Bracket. - NCRS Discussion Boards
  • Ralph B.
    • July 30, 2008
    • 178
    These clutch pedal brackets apparently have 2 ways to attach the mounting bolts. The lower bolt is through a elongated slot and the upper bolt appears to be able to go into either of the the 2 holes.
    What is the reason for having 2 holes?
    And which hole was originally used, the inboard hole or the outboard one?
    Thank you,
    Ralph
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Clutch Pedal Bracket.
    Originally posted by Ralph Benedetti (49275)
    ....What is the reason for having 2 holes ? And which hole was originally used, the inboard hole or the outboard one? ....
    Bolt in forward bracket hole = quick action (low) clutch pedal.
    Factory setting is rear hole (standard pedal height = higher).
    Also, don't forget the transmission levers (long throw [upper holes] = factory).
