1965 Roadster Window - NCRS Discussion Boards
  • Brenton M.
    • May 31, 2006
    • 66
    Could someone please help, I'm trying to install my windows after a full frame off restoration the windows was not installed when I disassemble the car, I had to install glass in window sashes, The problem I'm having now is on the right side window the glass does not align with the vent window frame, I cannot adjust the gap out of window there is a gap at top of window in vent window frame, It looks like the angle is not right on the window, Is it possible that I have the windows in wrong, Does the Logo on door window go to the front or to the rear of door, I have it at the rear of door on the passenger side.
  • Don H.
    Moderator
    • June 16, 2009
    • 2273
    Re: 1965 Roadster Window
    You're in backwards Brenton.
    The logo is at the front adjacent to the logo in the vent window, and all logos read correctly looking from outside the car.
    • Brenton M.
      • May 31, 2006
      • 66
      Thanks Don. I thought so but was not sure.
      • Ralph E.
        • February 1, 2002
        • 905
        Brenton, you will need to keep the window track runner loose or possibly even installed after you get the window into the track. OR you will need to install the vent window after you get the window in place.
