anti seize question - NCRS Discussion Boards
anti seize question
    • 15670
    Re: anti seize question
    How do you know by how much to adjust the torque spec to allow for the lubricity of the anti-seize?
    Jim
    You don't, although you can probably use the low end of the range, if the torque spec is a range rather than a single value.
    Most GM wheel nuts of the era are speced at 80 lb-ft, which is what I use, and they always torque up nice and smooth and consistent and the same on breakaway.
    Especially if you have multiple sets of wheels and tires, like I have for my cars and swap them frequently, anti-seize will save everything from galling damage.
    • Michael H.
      • January 29, 2008
      • 7477
      Here's a bit of info on lubed/dry bolt torque/load. I'll let ya'll add the coefficient of friction factor. (steel, lubed/dry)
      Some pretty amazing clamping loads.
      The wheel lug nut torque for most 63-67 Corvettes was around 50-60.
      • Dick W.
        • 10483
        My head hurts
        Dick Whittington
        • Clem Z.
          • January 1, 2006
          • 9427
          torque on aluminum wheels is 100# ft
          • Michael H.
            • January 29, 2008
            • 7477
            Is that for C6 Clem?
            • Clem Z.
              • January 1, 2006
              • 9427
              The Corvette Service Manual page 3-81 states 100 lb ft.
              • Michael H.
                • January 29, 2008
                • 7477
                For what year? Not 63-67.
                • Clem Z.
                  • January 1, 2006
                  • 9427
                  97 up and i did not ever see a 63-67 corvette with aluminum wheels back in the my 63-67 days. i think you need the 100# ft on "real" aluminum wheels because of the expansion and contraction due to heat on the new aluminum wheels where the nuts hold the wheels.
                  • Michael H.
                    • January 29, 2008
                    • 7477
                    #24
                    Looks like they increased the torque for the newer cars. I think all 63-67's were around 50-60 lb ft but it was raised to around 80 lbs for the 70's cars?
                    I think 67 with aluminum wheels were also 50-60?
                      • 15670
                      #25
                      The '63 ASM does list 55-65 lb-ft.
                      • William F.
                        • June 9, 2009
                        • 1363
                        #26
                        67 Chevy Service Manual, section 10-4 "Wheels and Tires", paragraph "Change (W/Wheels)" states:"Proper torque on nuts is 55-75 ft. lbs.(75-85 ft. lbs. for Corvette aluminum wheel nuts." not 55-65 or 100 or other values as some have opined.
                        • Michael H.
                          • January 29, 2008
                          • 7477
                          #27
                          The 63 AIM calls for 55-65 ft lbs. (ok, I missed it by 5 lbs)
                          The 66 service manual shows 55-65 ft lbs.
                            Michael -
                            All 67's, both steel and N89 aluminum bolt-on wheels, used the same lug nuts, and torque was 55-75 ft-lbs.
                            • Michael H.
                              • January 29, 2008
                              • 7477
                              #29
                              Michael -
                              Thanks John. That must be the year for the new longer stud?
                                Michael -
                                Dunno for sure - P&A shows they went from the 1-3/8" stud to the 1-3/4" stud in '65.
