Power Steering Pump Quandary - NCRS Discussion Boards
  • Curtis M.
    • July 15, 2007
    • 45
    Can anyone tell me if the discharge fitting or pressure union for the power steering pump can be purchased separately?
    My pump started leaking pretty badly and I pulled it to rebuild it. When I got it on the bench, I found that someone had cross threaded the power steering hose into the discharge fitting. The threads in the fitting are destroyed.
    I'm concerned my only option is that I have to buy a new pump just to get the fitting.
    Thanks in advance
    Curtis
    • 6950
    Re: Power Steering Pump Quandary
    Curtis, I am sure that this a part that is serviced with the pump, Your best bet is to talk a walk through a junk yard maybe theres a older GM car there, They must all be the same, just bring the old part with you.
      • 43247
      Thanks in advance
      Curtis
      Curtis-----
      The fitting, GM #5692843, was once available as a separate part. However, it was discontinued without supercession in June, 1981. I don't know of any source for a replacement. I suspect that such pieces are "out there" but likely only available to commercial rebuilders since there would be virtually no market for such parts in the retail automotive world.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11334
        Curtis, Try a call to Lonestar Caliper in Texas. They rebuild PS pumps along with calipers, etc. They may have some leftovers from salvaged non-rebuildable pumps.
        Rich
        • Curtis M.
          • July 15, 2007
          • 45
          Thanks guys
