What is the correct length of the hood seal. The new one I just purchased seems to be about 5 inches longer then the one I took off. How far up should it go on each side. The original measurement is about 16 inches on each side, Is this correct?
Is there any special way to install it? I doesn't looks symmetrical. If i look at it straight on the hole look oval is this normal for new seals. Should the long edge go on the hood and the shorter section on the support?
