Belts - NCRS Discussion Boards
Belts
  • W K.
    • December 16, 2009
    • 61
    Belts
    How many belts go on a 1966 L79 w/o air, power steering or smog pump? Do they all have 2 grove pulley's on the water pump and crank shaft?
  • Keith B.
    • March 7, 2008
    • 928
    Re: Belts
    You should have two. One from the crank to the water pump and the other crank to water pump to the alt.
    • W K.
      • December 16, 2009
      • 61
      Re: Belts
      Thanks, been on vacation. I appreciate your response. I guess you have to remove the water pump pully to install the first belt.
