Brake light problem - NCRS Discussion Boards
Brake light problem
  • David S.
    • August 9, 2009
    • 595
    Brake light problem
    Hi Guys,
    Both brake lights work perfectly without the headlights on. However, when you turn on the headlights and then hit the brake pedal, the passenger side brake light goes out.
    I've check to see if there is power on both socket terminals with the brake lights and headlights on and there is.
    Any suggestions?
    Dave
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: Brake light problem
    Almost always a bad ground or a crossed bulb socket.
    • Lawrence R.
      • March 23, 2010
      • 56
      Wayne, I think you hit the nail on the head with your answer!
      • David S.
        • August 9, 2009
        • 595
        Got it fixed.... Thanks guys.
        Dave
        • Brad H.
          • August 12, 2007
          • 724
          Was the bulb in wrong, I had one do that and found that the bulb was in wrong, must have been grounding wrong? Brad
          • David S.
            • August 9, 2009
            • 595
            To be honest, I'm not sure. I replaced the bulb with two different ones but also found a fuse blown. Now it all works, so I'm sure what it was but regardless it is fixed!
            Dave
