Throttle Shafts Carter AFB - NCRS Discussion Boards
  • Timothy B.
    • April 30, 1983
    • 5202
    Does anyone have a source for new throttle shafts (primary and secondary) for the Carter AFB carburetor. The carburetor in question is for a 1963 3461S AFB..
    Thanks for any help, Tim
  • Joseph S.
    National Judging Chairman
    • March 1, 1985
    • 930
    Re: Throttle Shafts Carter AFB
    Try Bob Kunz or Chuck Smith
    • Clem Z.
      • January 1, 2006
      • 9427
      after removing the levers you can turn down the shaft outside diameter in a lathe and shrink fit on some brass tubing of the correct outside diameter over the turned down areas. just like bushing the base plate only in reverse.
