57 4-speed tailshaft housing info needed - NCRS Discussion Boards
  • Mike E.
    • February 28, 1975
    • 5138
    On a BW I have with a 63-dated case, I discovered I have a T-10 7A tailshaft housing dated 4 05 57 Seems like that should be for a 57 model year, yet Colvin's book indicates that 7A was 58. Any ideas on the 7 vs. 7A? Also, any educated guesses as to value?
    Mike
  • Loren L.
    • April 30, 1976
    • 4104
    Re: 57 4-speed tailshaft housing info needed
    Mike, looking in my T10 folder (admittedly not kept up-to-date), the first
    T-10-7A that shows up is cast 11-6-57 (attached to a cast iron T-10-7 main case!), assembled late Nov '57(# is obscured) and in an early March '58 car.
    I'm also aware of a 1XXX '58 with an April 57 main and a T10-7 tailshaft, assembled June '57 (owner has had the car since 1961); I warned him to be sure the trans is the same one if it ever has to come out.
    Clearly NOTHING applies the "First In, First Out" rule.
    • Mike E.
      • February 28, 1975
      • 5138
      Anyone? It has the vertical half-moon cutouts per the JG--did that continue into 58 model year?
      • Loren L.
        • April 30, 1976
        • 4104
        Yes. (I have to make this longer because the Board objects to the short answer.....I think I have another short answer for the Board........)
        • Mike M.
          • May 31, 1974
          • 8388
          yes.mike( who also had to lengthen this post)
          • Mike E.
            • February 28, 1975
            • 5138
            Does anyone know anything more about 57 tail shaft housings. Any help would be appreciated!
            Mike
            • Gary C.
              Administrator
              • October 1, 1982
              • 17678
              Mike, post a photo of the T7A side of the extension showing the date, etc.
              Gary
              NCRS Texas Chapter
              https://www.ncrstexas.org/
              • Loren L.
                • April 30, 1976
                • 4104
                I'd be curious to know if anyone has ever come up with a decoding of "SPAC" on these tailshafts.....my best try would be "Special Performance
                Aluminum Case".......
