C1 (1960) radiator core support - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2594
    I need to replace the radiator core support on my 1960 project. It is a 270HP car, but is an early build and does not have the tank type radiator.
    Has anyone used the radiator core support from Paragon or Corvette Central? If so, how was the fit and look?
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11370
    Re: C1 (1960) radiator core support
    Don, I used the CC part, for a '59, which I believe is what Paragon also sells. I was generally pleased with it, except they got the upper forward corners wrong. I had to cut reliefs in it to match the original so the hood hinges would fit properly. I have some photos somewhere to show what I mean and will post later.
    Rich
    edit....found one on my website. This is the CC repro. If you look at a original with the hinges removed, the front top on each side is cut inwards about 1/8" to 3/16" with a slightly curved appearance.
    • Donald H.
      • November 2, 2009
      • 2594
      Rich
      Thanks, I'll be sure and keep the original to work from. The one I have now, which I assume us original, has rusted through on the bottom
      Don Harris
      • David A.
        • July 31, 1999
        • 147
        just curious
        many parts, especially my wwii jeeps,
        if i coudn't find an original piece,
        i'd buy a repro
        and cut out the part i needed from it
        and weld in onto the original.
        would this have been possible with your support?
        dave
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11370
          Dave, The common problem with these is that the bottom rusts out, so it's very unlikely to find a donor piece. It's possible to refabricate and rebuild, but it is quite a project to attempt.
          In my case the original was badly rusted at the bottom, and crumpled and re-bent from a accident in the early 60's, according to my friend who owns the car.
          • Donald H.
            • November 2, 2009
            • 2594
            I would love to save the old one, but it has rusted through in the bottom and the square holed for the carriage bolts that make uP the front mount are rusted and will not hold. It probably could be repaired, but I don't have a welding rig and it I'm not sure what else I would find if I cut the bottom piece off. I'll look at Carlisle for a good original if I can wait that long.
            Don Harris
            • Norris W.
              • December 1, 1982
              • 685
              Just out of curiosity, what is a good original one worth?
              • Ian G.
                • September 3, 2007
                • 1141
                I bought a good used one on eBay a while back for $180 shipped. Same situation. My original was rusted out on the bottom and the welder said it would cost more than a repro to fix it, so I held out for a good used one. eBay is not so good anymore for finding stuff though. A lot of sellers abandoned it due to the fees.
                • Donald H.
                  • November 2, 2009
                  • 2594
                  I've been looking on EBay and elsewhere.
                  Don Harris
                  • David A.
                    • July 31, 1999
                    • 147
                    the two carriage bolts on the bottom were always loose
                    on my '56, and i could not tighten them w/o taking out the radiator
                    well.....since i just 'freshened' my engine bay
                    i finally got them two bolts tightened!!
                    dave
                    • Scott K.
                      • February 1, 1980
                      • 59
                      Rich
                      Just an FYI to everyone that our latest radiator core support has been revised with respect to the condition described here.
                      Anyone who purchased the older support can send theirs to us for modification.
                      Corvette Central
                      800-345-4122
                      www.corvettecentral.com
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11370
                        Here are 2 photos of my original support on my '59, and 2 of the CC support after I modified it.
                        Scott, good that you saw this thread. As you can see, the original support shows that the horizontal piece is set inwards about 1/8" or so from the edge as well. Your reproduction horizontal is flush with the edge. Maybe on the next run kick both edges in a bit.
                        Rich
