Verify finish on starter motor - NCRS Discussion Boards
  • Steve L.
    • June 30, 2001
    • 763
    I'm guessing at the finish, This is for 72 SB:
    Starter frame bolt bottom zinc bolt 6 inch long 1/4-20 thread
    Starter frame bolt top zinc rod 6 inch+ long 1/4-20 thread both
    ends flange head nut, lockwasher,
    second nut
    Solenoid to nose zinc pan head phillips 1/4-20
    Shift lever pivot zinc 1 3/4long, 5/16-18, split lock, thin
    nut
    Starter to block black phosphate 3 5/8 long, 3/8-16, split lock
    hash marks on shaft near thrds
    What's the purpose of the hash marks on the mount bolts?
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
    • 15609
    Re: Verify finish on starter motor
    Those hash marks are called knurling and make the diameter of the bolt slightly larger in the area where they are. This is the interface between the starter and the cylinder case. They help keep the starter from moving against the torque of cranking the engine. I remember a post recently with a picture of the corner of the case broken off at one of the starter threaded holes. That happens if one uses bolts without this knurled segment or if one fails to use the starter support at the other end of the starter.
      • 43246
      Terry------
      .....and a block damaged in this way is, essentially, irreparable.
      • John P.
        • August 31, 1991
        • 94
        The solenoid to "nose" screw is a filister head.
        • Steve L.
          • June 30, 2001
          • 763
          Thanks John,
          I checked it again and it is a fillister head rather than pan head.
          Steve L
          73 coupe since new
          Ottawa, Canada
