68 steel wheels - NCRS Discussion Boards
68 steel wheels
  • Jim R.
    • June 30, 2001
    • 643
    68 steel wheels
    Can anyone tell me what cars other than the 68 corvette came with the 7x15" Rally wheels.
    JR
  • Dick W.
    • 10483
    Re: 68 steel wheels
    To my knowledge, they were unique to Corvette
    Dick Whittington
    • Jim R.
      • June 30, 2001
      • 643
      Re: 68 steel wheels
      Thanks Dick. jim
      JR
      • David L.
        • July 31, 1980
        • 3310
        Re: 68 steel wheels
        Jim,
        The 1968 Corvette 15X7 rally wheel is stamped "AG".
        The 1969 Camaro Z28 and 1970 Monte Carlo 15X7 rally wheel wheel is stamped "YH". This wheel was replaced by a similar 15X7 rally wheel stamped "FW" (and then "Z") that was used on the 1971-1977 Monte Carlo.
        I believe that the difference between these wheels is the offset.
        I have a "FW" 15X7 rally wheel that measures about 8 1/16" or 8.06" (gross width). The backspacing measures about 4 5/16" or 4.31". The offset would be 4.31"-4.03"=0.28" or about 9/32".
        Dave
        • David L.
          • July 31, 1980
          • 3310
          Re: 68 steel wheels
          Joe,
          According to Colvin's "Chevrolet by the Numbers" books the "AG" wheel has an offset of -0.28" and the "YH" & "FW" wheels have an offset of 0.30" (I was off by 0.02" measuring my "FW" wheel).
          The net difference would be 0.58" so if your put a pair of "YH" or "FW" wheels & tires on a 68 Corvette the track width would be 1.16" narrower then with the original "AG" wheels. I believe that this is correct.
          Dave
          • Ray K.
            • July 31, 1985
            • 372
            Re: 68 steel wheels
            There is a catalog listing for 1970 Camaro with SPH 350 using a 15 x7 wheel also, part #3983044
            Ray
              • 43221
              Re: 68 steel wheels
              Originally posted by David Liukkonen (3775)
              Joe,
              Dave
              Dave------
              Yes, you're correct. I mis-read the Corvette offset as POSITIVE when it's actually NEGATIVE. The other wheels are POSITIVE. So, there is no other original Rally Wheel with anything near the 1968 Corvette wheel off-set.
              By the way, I deleted my previous post so that the inaccurate information I provided does not find its way into the archives.
              Last edited by Joe L.; May 23, 2011, 10:49 PM. Reason: add comment regarding deleting previous post
              • David L.
                • July 31, 1980
                • 3310
                Re: 68 steel wheels
                Ray,
                The 70 Z28 wheel (GM # 3983045 w/"AU" code) is not a rally wheel.
                Dave
