Brake fluid/hoses - NCRS Discussion Boards
Brake fluid/hoses
  • Jim T.
    • March 1, 1993
    • 5351
    Brake fluid/hoses
    Below copied from a web page.
    OEM BRAKE FLUID RECOMMENDATIONS
    What do the auto makers say about fluid changes? General Motors and Chrysler do not mention brake fluid in their scheduled maintenance recommendations. A General Motors spokesman said Delco Supreme 11 DOT 3 brake fluid contains additives than many other brake fluids do not, so it is essentially a lifetime fluid. Starting in 1993, GM began using a new type of rubber brake hose with an EPM lining and outer jacketing that reduces moisture penetration by 50%. So GM does not consider fluid contamination to be a significant problem.
    I did not know about GM using a new type of rubber barake hose.
    Anyone have a recommendation on the length of time a unopened/sealed plastic container of Castrol DOT4 can sit on a shelf and still usable for a fluid change?
  • Larry M.
    • January 1, 1992
    • 2693
    Re: Brake fluid/hoses
    I would say indefinitely. No moisture pickup, and no heat to promote decomposition or degradation, so it should be unchanged from new.
    Larry
      • 15600
