Torquing The Rear Leaf Spring Retainer? - NCRS Discussion Boards
  • Don L.
    • August 31, 2005
    • 1005
    Soooo, yesterday, my trusty assistant and I (he can jump in here if he wants to admit working with me) are installing a new 9-leaf spring on my '72. Not without some complications, we get all back together and when we put weight on the spring to torque the 4 retainer bolts, we can't get the specified 60-80 ft lbs. It feels like I'm going way too far with the wrench and the retainer ears start to bend. This causes me to think that I'm getting a false torque reading due to the "soft" base of the bending retainer, and stopped. The bolts feel plenty tight but I thought I should ask this group for advice before proceeding. Help please.
    Don Lowe
    NCRS #44382
    Carolinas Chapter
  • Paul B.
    • April 30, 1995
    • 482
    Re: Torquing The Rear Leaf Spring Retainer?
    ...did you do it with the car up in the air??? I believe it's supposed to be done with the weight of the car on the spring itself so your tightening it when it's "flattened out" vs no weight on the car and the spring is very arched.
    • Don L.
      • August 31, 2005
      • 1005
      The weight of the car WAS INDEED on the spring. The car was "in the air", but was on my 4 post lift, giving me the weight of the car on the spring, but the convenience of standing under the spring to work.
      Don Lowe
      NCRS #44382
      Carolinas Chapter
      • Larry M.
        • January 1, 1992
        • 2695
        Don:
        I experienced a similar thing. I just was not certain that the retainer or the cast housing ears were strong enough to take the stated torque. So I basically tightened them by hand until I thought they were tight. The measured torque after this was about 1/2 the book value. (Disclaimer: Never-seize was used on the bolts, which will lower the required torque numbers)
        I my case, BUBBA had cross-threaded one of the four spring mounting bolt holes, so I was very cautious when assembling the spring. I rethreaded the bolt hole in the housing, but it was a bit "loose" compared to the others. I have had threads strip out before when I tried to tighten to the book numbers.....especially in aluminum
        Larry
        • Jeffrey S.
          • May 31, 1988
          • 1882
          We used 2 different click type torque wrenches, both set to only 50 ft lbs. and neither reached the click point so we stopped before we broke/stripped something.
            • 3416
            Hi Don,
            Didn't the width of the spring leaves change at some point?
            If the leaves are narrower, wouldn't that allow the plate ears to deform since they're not completely supported by the leaves?
            Do you have the right spring?
            Just a thought.
            • Don L.
              • August 31, 2005
              • 1005
              Good question Alan. Thanks for pointing this idea out.
              The very incorrect replacement spring that was on the car was approx 2" wide. The new spring is more like 2 1/4" wide. Accordingly, wouldn't I expect to see an improvement with the wider spring over the narrower one? I should have checked torque before disassembling - darn!
              Don Lowe
              NCRS #44382
              Carolinas Chapter
