'67 327 Fan Blade - NCRS Discussion Boards
'67 327 Fan Blade
  • Gary B.
    • February 1, 1997
    • 7020
    '67 327 Fan Blade
    Originally posted by David Plittman (52742)
    ...Follow on: Any idea as to a fair price for a NOS 3770529 blade?
    David,
    The 3770529 fan is still available from GM for a list price of $104.91. You can get it from gmpartsdirect.com for $75.63 including S&H.
    It almost certainly has FRONT stamped into the front and will be missing the W stamping on the back.
    Gary
    • Peter L.
      • May 31, 1983
      • 1930
      Re: '67 327 Fan Blade
      Gary - While the currently available 66-67 sb fan blade assembly for non-C60 Corvettes is reasonably priced and functionally OK, the versions I have seen are "ink" stamped FRONT on the center hub and have interesting flat head button rivets that have a combination of 3 alphanumeric characters stamped in them, plus they do not the the "H" stamped into the center hub and no "W" stamped into the back of one the support arms. Pete
      • Gary B.
        • February 1, 1997
        • 7020
        #18
        Pete,
        I didn't know about the characters on the rivets. That and the missing W should be spotted by a good judge.
        Gary
        • Jim C.
          • April 1, 2006
          • 290
          #19
          My first 1966 (#16401) 327/300 non AC fan only had an H stamped on the front center hub and a W on one of the blade arm backs. Same stamps on my current 1966 (#27592) 327/300 non AC fan. No "FRONT" stamp on either one.
          Jim C.
          • Gary B.
            • February 1, 1997
            • 7020
            #20
            Jim C.
            Jim,
            I think the conclusion for originals fan is: an H on the front; a W on the back; and nothing else.
            Gary
            • David L.
              • July 31, 1980
              • 3310
              #21
              Originally posted by Gary Beaupre (28818)
              Jim,
              Gary
              I agree.
              Dave
              • David P.
                • February 1, 2011
                • 69
                #22
                So if one was to hypothetically find a letter "W" stamp that was the correct font, would NCRS object to self-stamping the "W"?
                Thanks.
                • Wayne M.
                  • March 1, 1980
                  • 6414
                  #23
                  So if one was to hypothetically find a letter "W" stamp that was the correct font, would NCRS object to self-stamping the "W"? ...
                  You should probably be looking for this font, on my big block [has '66' and 'FRONT' on the other hub side].
                  Oops, forgot to add that the front side also has the [skinny] letter 'H'.
                  • David L.
                    • July 31, 1980
                    • 3310
                    #24
                    Thanks.
                    If that was to happen I believe that a NCRS-CSI would be created and our dues would go up.
                    • Peter L.
                      • May 31, 1983
                      • 1930
                      #25
                      David - If you did that, it would be the first time anyone ever did that. Pete
                      • David L.
                        • July 31, 1980
                        • 3310
                        #26
                        Pete,
                        I don't quite understand your comment. I would never even think about faking a part as I could care less about Corvette "points". The only points that I care about is how many the Patriots score.
                        Dave
                        • Peter L.
                          • May 31, 1983
                          • 1930
                          #27
                          Dave - A "tongue-in-cheek" comment. Numerous things have been done to get 'judging" points and some attempts are easily detectable and others are "spot-on" and are very difficult to detect and present a challenge during judging.
                          Patriots "points? More important down here in the Land of Enchantment is the "heat" of the green chiles on the Scoville index. Pete
                          • David P.
                            • February 1, 2011
                            • 69
                            #28
                            Thanks for all the good comments!
                            And Wayne, thanks for the pic!
                            DAP
