small block intake manifold - NCRS Discussion Boards
  • Jim M.
    • February 23, 2009
    • 233
    On a 69 small block, is there a reason why the middle area of the manifold, where it meets the heads, discolors the paint?
    • 43271
    Re: small block intake manifold
    Jim------
    This occurs on most small blocks, not just 1969. The intake manifold has an exhaust heat cross-over passage. When the heat riser is closed, the exhaust is directed through the cross-over passage to the left side manifold. Even when the heat riser is open some exhaust gas may enter the passage. The purpose of the cross-over is to activate the divorced style choke used for 1966-74 models and to provide heat to the carburetor base to improve fuel atomization.
    The exhaust heat inevitably discolors the paint on the intake manifold in the vicinity of the cross-over. It also discolors aluminum manifolds in this vicinity.
    • Jim M.
      • February 23, 2009
      • 233
      Thanks Joe, that makes sense. Jim
