All,
I did a little archive searching, but didn't find the answers. So here it goes. The car is a 66 L72 (427 / 425 hp), so K66 (TI) comes along for the ride. My first question is who restores them? I seem to remember that Mike Zamora and Dave Fielder both do. Is either one of them a good choice? Is there anyone else? How much, roughly, does it cost?
Here's a quote from the TIM&JG: "The factory installed distributor is painted semi-gloss black." What is the best paint to use?
Here's another quote from the JG: "Restored distributors and current replacements may have a relief hole through the housing at the forward thrust end of the tachometer drive gear location which is incorrect." Can anyone provide a picture of the relief hole?
Here's one last quote from the JG: "The distributor is held in place by a formed wire retainer secured with a clip and hex-head bolt. A known original head mark is "TR" or "SBC." Mine is a repo, the head mark is a "M." Where should I get a new bolt?
Joe
Joe
]; its a hole into which the nylon thrust button tit inserts (from the inside). This was a factory revision, starting sometime in mid-calendar 1970. But some shops drill and thread the earlier no-hole for an external adjustment (with lock nut).
