68 power brake install - NCRS Discussion Boards
  • Jeff P.
    • 799
    I read on a past post, can't find it now that I believe it was Joe Lucia stated that the manual pedal is different from a power brake pedal. I have all correct dated parts but want to make this right. Thanks, jeff
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
    • 43290
    Re: 68 power brake install
    Jeff-----
    The brake pedal with manual brakes is the same as the pedal for cars with power brakes.
    The only difference in the pedals relates to whether the car has automatic transmission, or not.
    • Jeff P.
      • 799
      Thanks again for your help Joe. I also remember reading that there is a spring you remove for power brakes ? In the manual it shows a bracket that is lowered for PB. Jeff
