73 Starter solenoid contact ring coating - NCRS Discussion Boards
  • Steve L.
    • June 30, 2001
    • 763
    If you look at the attachment, you can see the gray material that is on most of the surface(underneath,sides and on top) except for an exposed copper ring where the main Battery contacts.
    They gray material is an insulator. Placing an ohm meter across this material shows no contact what so ever. But this is where the "R"terminal is supposed to contact. Needless to say that I don't get 12V on the R terminal with the solenoid engergized. Which is why I took this solenoid apart once again.
    Anyone know what "plating", if any is supposed to be on the contact ring or what this material is? I'm guessing it is corrosion. But I thought I'd ask first before I Dremel wire wheel this stuff off.
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: 73 Starter solenoid contact ring coating
    Steve, I can't expand your photo so I can't see the ring. If you are talking about the round flat copper ring that moves when the solenoid is energized, it should be completely conductive. This ring is designed to move in a circular motion to distribute the wear from the arc when the starter is engaged. It should also be clean of any debris and corrosion. Clean it off and you should be good to go.
    • Steve L.
      • June 30, 2001
      • 763
      I reposted the picture
      Steve L
      73 coupe since new
      Ottawa, Canada
      • Stephen L.
        • May 31, 1984
        • 3158
        That disc definitely should be completely clean copper and also the contacts.
        • John P.
          • August 31, 1991
          • 94
          The contact disc could have been copper or cadmium plated copper.It should conduct either way.If it doesnt,you have corrosion and it should be cleaned off.
          • Steve L.
            • June 30, 2001
            • 763
            I was actuallly wondering if it was cad plated and what I'm seeing is cad corrosion. I'm not familiar with what cad corrosion looks like. This coating is really hard- I can't get through it using sharp multimeter points and the ohm meter doesn't show any continuity.
            I'll assume it's cad corrosion then dremel wire wheel it gently to see if I can get through the corrosion.
            Otherwise, I'll go right down to the copper.
            Thanks all
            Steve L
            73 coupe since new
            Ottawa, Canada
