Spark Plug Wire Resistance - NCRS Discussion Boards
    • 15706
    Re: Spark Plug Wire Resistance
    Have you played with the idle mixture screws? Start with the CSM initial setting and go lean and rich from there. Do not complete the procedure using the "lean drop" method if that's what the book says. Adjust the screws to achieve the highest vacuum/idle speed with a target speed of 900.
