just drained my oil out and getting ready to refil - however can't find anything advising which gear oil to use along with how much and should one use a natural or synthetic blend and how much additive to use? Thanks Jim
336 Posi
Re: 336 Posi
90 wt gear oil. Be sure you use GM posi additive. Fill to the edge of the fill hole.- Top
Re: 336 Posi
The original Mil-L-2105 spec from the sixties was replaced by SAE 80W-90 GL-5, which is commonly available in parts stores. Brand is not important - just the spec.
One bottle of Positraction additive will probably be enough to prevent chatter, but if it occurs add another half bottle.
Don't fill the axle quite full to the bottom of the plug at first. Leave about a quarter inch free space.
"Full" is to the bottom of the plug HOT, not cold. Once you have a sufficient amount of Positraction additive you can then fill the axle to the bottom of the hole when the oil is hot.
The nominal specified capacity is 3.7 pints.
Duke- Top
Re: 336 Posi
Gary - thanks for the input - it has just been so confusing - i wanted the GM products but can not find the oil but found the additive. Again thanks Jim- Top
Re: 336 Posi
As for you also - Michael - Thanks for the input - it just got so confusing - I looked for GM gear oil but can not find it - have found the additive - Again thanks - Jim- Top
Re: 336 Posi
Duke - Thanks for the input - It has just been so confusing - wanted the GM products but can only find the additive. Again thanks Jim- Top
Re: 336 Posi
Paul -thanks for the input - it became so confusing and wanted the right stuff and only could find the additive. Again thanks Jim
By now everyone can see i am new at this stuff because i answered everyone seperately THANKS to ALL Jim- Top
