Half shaft u-joint straps and nuts - NCRS Discussion Boards
  • John M.
    • January 1, 1998
    • 813
    In the 65 judging manual it says the half shaft u-joint straps and hardware may be bare steel or black phosphate. Is the black phosphate still acceptable? Seems better than bare metal if the judges like it.
    John McRae
    30025
    65 L84
    • 43279
    Re: Half shaft u-joint straps and nuts
    John McRae
    30025
    65 L84
    John------
    Every GM u-bolt for the half shafts that I've ever seen has been black phosphate-finished. I have never seen a "plain" or "natural" u-bolt.
    • John M.
      • January 1, 1998
      • 813
      Thanks Joe,
      I got this neat little kit for what the maker calls parkerizing. I believe the reaction is between manganese phosphate and the steel. It makes for a nice looking black "phosphate" finish, black to dark gray. Heat up the solution, toss the blasted bare steel part in, cook until the fizzing stops, coat with special oil and voila.
      Probably wouldn't want to drink it...
      • Jeffrey S.
        • May 31, 1988
        • 1899
        John,
        Whose kit did you buy?
        Jeff
        • Tom L.
          • October 17, 2006
          • 1439
          Jeff, I did some parkerizing this winter, it went real well. I was referred by another TDB member to the shooters solution kit. The instructions are very wordy, almost intimidateing but as a friend of mine told me, "A monkey can do it."
          Good news!!! I'm smarter than a monkey.
          This is the kit:
          Good luck!!
          • John M.
            • January 1, 1998
            • 813
            Jeff, I used the same stuff as Lynn.
            Throw away the written instructions, they are in some foriegn language.
            Use the instructions on the containers.
            Clean parts thoroughly. I use fine glass beads.
            Heat solution to 180-200f is SS pot
            Place parts in solution and leave till fizzing stops
            Rinse in clean water.
            Spray with oil included
            The stuff works very well and the finish is pretty rugged
            Store solution in glass jars.
            Use in ventilated space, outdoors is good.
            John
            • Jeffrey S.
              • May 31, 1988
              • 1899
              John,
              That's the stuff I have and it works very well. The owner of the company really wants to please and will do whatever it takes to help you with the process. Apparently he wrote the directions and they are a bit confusing and if you call to ask you will be on the phone for quite some time but, as I said, he really wants to help. The problem is that if you ask him what time it is he will tell you how to make a clock! But I wish all vendors were as sincere in wanting to give such good customer service.
              Jeff
              • John M.
                • January 1, 1998
                • 813
                Jeff,
                That's good to know; in this world good cutomer service is becoming an obsolete concept.
                I put off using the stuff for a couple of months because of the instructions; but I got to a point where I had to try and was suprised at how simple it was. Probably should have called like you did.
                Thanks for filling me in.
