1964 gage cluster - NCRS Discussion Boards
1964 gage cluster
  • Ernest B.
    • October 22, 2006
    • 4
    1964 gage cluster
    Would like to replace bulbs on gages and also the odometer does not work. What do I need to know about removing the gage cluster? Ernie
  • Doug L.
    • March 14, 2010
    • 442
    Re: 1964 gage cluster
    If I recall correctly the cluster is attached from the front with 5 black phosphate plated screws arranged around the upper perimeter. There is an oil line connected to the oil pressure gauge and cables connected to the speedometer and tachometer. You should disconnect those before removing the screws and pulling the cluster away from the dash. The wiring harness connections to the various bulbs, gauges and switches will limit how far you can move the cluster but you should be able to pull it out far enough to access what you need.
    Doug
      Ernie -
      Try these two articles - one for midyear cluster removal, and one for installation:
      http://www.lbfun.com/warehouse/tech_...ster%20pt1.pdf
      http://www.lbfun.com/warehouse/tech_...ster%20pt2.pdf
      • Alan D.
        • January 1, 2005
        • 2054
        Just a minor clarification, the cluster screws are brown not black for a 64.
          • 6960
          Ernie, if you un-hook the oil pressure line from the engine, this will let you slide the cluster forward to un-hook the pressure line instead of laying on your back on the floor. The same also applies to the tach cable , the speedo cable will have to reach hand under dash to remove.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11367
            Pull the steering wheel and drop the steering column from under the dash to give you better clearance.
            Acquire 5 bolts, 1/4-20, 8" long and one at a time replace the 5 1/4-20 screws.
            Slide the cluster towards you on the long bolts.
            Get pillows, blankets, lighting. You're going in!
            Pull the tach and speedo cables, the oil line at the gauge, and other misc stuff like trip odometer cable. Note the routing of everything.
            Get under and mark every wire connector and bulb with tape before removal. Make a picture diagram.
            Ok now the cluster is on the bench. Remove the speedometer. Send to a shop to replace the speedo head gear and side gear. They just plain wear out.
            I just did all of this on a '67 recently. I brought speedo to Bill Harrison in Jupiter Florida......all fixed!
            Rich
            p.s. pull the seat to make it a little easier.
            • Ernest B.
              • October 22, 2006
              • 4
              Thank you, I'll give it a try. Ernie
              • Ernest B.
                • October 22, 2006
                • 4
                Ernie -
                Thanks, very helpful articles - Ernie
