66 Coupe Vent Window Weather Strip Replacement - NCRS Discussion Boards
  • Brian K.
    • September 19, 2007
    • 174
    I want to replace these and wondered if it is possible without removing the vent window assembly. Has anyone done this?
    Thanks!
    66 Coupe
    66 Convertible
    2022 2LT Coupe
    67 Chevelle SS396
    67 XLCH HD Sportster
  • Jim D.
    • 2884
    Re: 66 Coupe Vent Window Weather Strip Replacement
    I just did this on my 65. You must remove the whole assembly from the car AND remove the vent window from the assembly.
    • Brian K.
      • 174
      The little riveted hinge is loose on the frame. What is the repair for that? Also do you know if there is any difference in the quality of the replacement w/s from the different vendors?
      Thanks for the help
      66 Coupe
      66 Convertible
      2022 2LT Coupe
      67 Chevelle SS396
      • Jim D.
        • 2884
        You can buy the rivets and do it yourself or send it out to be done. The W/S from Corvette Rubber Co. is identical to the original.
