Survey - NCRS Discussion Boards
Survey
  • Ken A.
    • July 31, 1986
    • 929
    Survey
    Any interest in stock eproms/memcals from 84 to 93. Just respond with year & type you're intested in (auto or manual). Thanks,
    Ken
  • Ken A.
    • July 31, 1986
    • 929
    Re: Survey
    Are there any C-4 owners on the forum?
    • Richard C.
      • July 31, 2001
      • 144
      Re: Survey
      anny 82 fed proms?
      • Peter M.
        • April 8, 2007
        • 570
        Re: Survey
        Yes, 1986 w/ aluminum cylinder heads & manual transmission.
        • Ken A.
          • September 30, 2002
          • 167
          Re: Survey
          '88 35th Anniversary (McClellan & Crossed Flags)
          '91 ZR-1
          (plus several others, all generations except C5, all drivers)
          Ken
          • Bill M.
            • April 1, 1977
            • 1386
            Re: Survey
            '92 LT1 Z07 going for McLellan in Novi.
            Not sure why I would want an EPROM and don't know what an memcal is...
            • Pat M.
              • April 1, 2006
              • 1588
              Re: Survey
              What are eproms and memcals?
              • Edward J.
                • September 15, 2008
                • 6961
                Re: Survey
                Pat, those are the programs that GM installed on there computers, they were changed out when they had a driveabilty problem that could not be fixed by the routine adjustments, I replaced many when I was a GM tech. they put into the top of computers circuit board.
                • Pat M.
                  • April 1, 2006
                  • 1588
                  Re: Survey
                  Thanks Edward, I'd never heard of these.
                  • Alexander C.
                    • June 20, 2010
                    • 353
                    Re: Survey
                    EPROM: Electronic Programmable Read Only Memory. These are the black chips with the legs, these hold the .bin file the ECU reads.
                    MEM-CAL. This is the blue/brown (depending on year) housing which contains the EPROM and CAL-PAK (depending on year). The CAL-PAK is the knock circuitry. Because of the CAL-PAK being VERY engine specific, you MUST have the correct MEM-CAL for your EXACT engine, once you have that you can flash any .bin file you with onto the EPROM. The CAL-PAK is hard wired into the MEM-CAL and you can't swap this easily at all. I like to replace the EPROM chips with EEPROM chips so I can erase them via USB and not a UV light (which takes hours).
                    Long story short, NEVER store these with the sun can reach them either
