Hi again
I have just mounted my new Starter with only 2 Bolts
The last bolt, this in the top should be mounted from back and through the Bellhousing into the Starter, but its not possible to do that because all 3 Bolts have the same size but the "hole" in the bellhousing are too little??
Other here on the Forum who have the same problem.
C1, 1959 with powerglide.
The last bolt, this in the top should be mounted from back and through the Bellhousing into the Starter, but its not possible to do that because all 3 Bolts have the same size but the "hole" in the bellhousing are too little??Other here on the Forum who have the same problem.
