I was doing some work last weekend on the engine compartment of my 1974 350 in anticipation of getting (within a reasonable cost) the A/C working again. My local GM dealer has a grey-haired fellow who can do a diagnosis on this stock old R-12 system as an inexpensive start. (If taken further I will need an R-134 conversion according to Canadian law.) I asked a few questions on CF but the answers were vague. So here I am.
I disconnected the electrics a couple of years ago (but left intact taped to a wiring harness) and removed the drive belt. The belt is back on and the electrics can be done in five minutes.
I could not find the heater control valve. I have worked on C3s before and it is normally in the 5/8" hose near the coolant overflow tank and vacuum operated. Hmmm...a previous owner must have removed it. I checked the various catalogues and only Paragon lists one (#12466 for 1969-74). The others have no listings for 1972-74. That led me to the AIM and lo-and-behold the 1974 350 with C60 did NOT have a heater control valve!
This raises a host of questions. Why did GM design a system where a heater core with hot coolant flowing through is placed next to an A/C evaporator? This will surely cut down on cooling efficiency. I have installed a ball valve to cut the flow manually to the core but my Q. is: Why was the heater valve omitted 1972-74?
