1957 grille teeth - NCRS Discussion Boards
1957 grille teeth
  • Jason W.
    • January 31, 2011
    • 46
    1957 grille teeth
    In removing the grille teeth, we noticed that the markings were different on the underside of them. Are they originals or repos? Any ideas?
  • David A.
    • July 31, 1999
    • 147
    Re: 1957 grille teeth
    i remember dissassembling
    driving to Botavia, Iowa
    to have them chromed,
    and reinstalling my grille teeth.
    i was quite a job!
    unfortunately, i did not take any close ups
    of them as you have done above.
    how many vendors sell such repro corvette parts
    iowa
    • Bruce B.
      • May 31, 1996
      • 2930
      All parts vendors sell reproduction Corvette parts although they are manufactured by only a few.
      • James G.
        • May 31, 1976
        • 1556
        Total 13 teeth. ORIGINALS were numbered 1, 4 , 5 and 6 inside as you show. The center tooth was marked 'C' , then three #1 teeth, and then one each 4, 5, and 6 are mounted to the outside. I think you have a #5 but I can not tell with these old eyes.
        The three outer teeth are progresively smaller. Service replacement teeth may show a "nose" less pointed than originals.
        • James G.
          • May 31, 1976
          • 1556
          The left unit says BLC then 3/08 and somthing else. My vote this is the REPO. The right photo is the ORIGINAL and has the GM Part number inside left and possibily #5 stamped in the end, which means it would fit on the #2 position on the grill bar from outside either side.
          • Jason W.
            • January 31, 2011
            • 46
            i was quite a job!
            iowa
            Nice iowa...looks like ours does . Even to the point of under the window
            We seem to have some extra numbered ones and missing others numbers. I have read about them not being "sharp" enough with repo or rechomimg. Looking at grilleteeth.com for replacements
