Alt Brace bolt ID - NCRS Discussion Boards
Alt Brace bolt ID
  • Patrick N.
    • March 10, 2008
    • 961
    Alt Brace bolt ID
    I am trying to confirm the correct bolt to use: can someone comment on the correct bolt I would need for 68' L68 w PS that connects the lower threaded hole on the alt with the adjustable bracket?
    Grade 2 or 5?
    Zinc?
    Particular headmarkings?
    5/16 -18X1"?
    Lock wahser + star washer?
    thanks as always,
    Pat
  • Rich P.
    • January 12, 2009
    • 1361
    Re: Alt Brace bolt ID
    Pat ,
    68 was the change over year from grade 2 to grade 5. The right bolts is 5/16-18x1" grade 5. preferred headmarking WB but many others used. 68 was also the chance over year from star washer to split ring lock washers.
    Rich
    • Patrick N.
      • March 10, 2008
      • 961
      Thanks Rich!
      This was one of those little details that I could not seem to sort out.
      pat
