Engine Starter Motor from USA Industries - NCRS Discussion Boards
  • Jorn J.
    • October 21, 2008
    • 142
    Hi Friends
    I have just bought a rebuild "Starter" here in Denmark and wonder why they called one of the terminals on the Solenoid "R" instead of "C" ? I assume that its the same function whatever its the letter R or C.
    Is it right the the Terminal B are Battery and AmMeter and Terminal R/C are to resistor(green) and Terminal S are violet to ignition Switch?
    The car are from 1959.
    Regards Jorn
    • 6950
    Re: Engine Starter Motor from USA Industries
    Originally posted by Jorn Jarnved (49584)
    Hi Friends
    Regards Jorn
    Jorn, The terminals should be the same positions R-(Purple wire), S- is Ignition wire from ballest,( green I Believe)
      Hi Friends
      Regards Jorn
      Jorn -
      The small terminal closest to the block ("S") is for the purple/violet wire (energizes the starter), and the small terminal on the outboard side ("C" or "R" for "relay" originally) is for the green coil bypass wire that provides a full 12 volts to the coil (+) terminal when cranking.
      • Jorn J.
        • October 21, 2008
        • 142
        Thanks John and Edward
        I will mount it today
        Regards Jorn
