Testing new bulbs before installing 1963 dash cluster - NCRS Discussion Boards
  • Doug Y.
    • January 15, 2009
    • 62
    Is there a trick way to test the new bulbs I have purchased to make sure they work before installing the cluster. Should I just test each bulb individually with a 12 volt source? Thanks for all replies.
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11325
    Re: Testing new bulbs before installing 1963 dash cluster
    I recently did the same, I just installed all of the bulbsl(I had the cluster out), and then used a ground wire and touched each socket for a few seconds to test them. This checks the socket ground also.
    Rich
    p.s. If chinese bulbs, extend test time 300%.
    • John L.
      • February 20, 2009
      • 186
      Use a 9 volt battery is a quick way to see if they light up at least. No way to tell how long they will last
