67 column questions - NCRS Discussion Boards
67 column questions
  • Keith B.
    • March 7, 2008
    • 928
    67 column questions
    for a 67 tele column and the upper baring how is that held in place in the aluminum part. the column I am working on looks to have been worked on in the past and the notches in the aluminum part have been wore down. is that part the same on any other GM cars. any in-site would be helpful
  • Rich P.
    • January 12, 2009
    • 1361
    Re: 67 column questions
    Keith the upper bearing is installed into the pot metal housing by pressing peening over the lip on the housing. The repro houses sell the bearing but not the whole assembly. Contact Tom Reina in SC he is the man to go to for these parts. He got me a good used assembly for my last 67 tele colum. Just google his name and corvette steering and it will give you his info.
    Rich
    • Keith B.
      • March 7, 2008
      • 928
      thanks hopefully I can get this column in working order
      • Nick L.
        • May 31, 1998
        • 82
        Keith is this an early or late column? I went through my non-tele EARLY 67 column a couple years ago and found few resources for information or parts on this orphan design. Let me know if you have any questions, will do my best to help.
        • Brian T.
          • September 30, 1990
          • 190
          The upper bearing housing is the same on all 67 and 68 columns, standard or tele. If you find a used part from a standard column, it will be much better than the tele part. Tends to pull out over time especially when the tele adjustment is too tight.
          • Jim S.
            • August 31, 2001
            • 730
            Corvette Steering Service has a 67-68 housing and bearing listed as:
            67-68 Upper Steering Column Bearing (in housing) reconditioned used (all columns reg & tele)
            http://www.corvettesteering.com/corvette%20parts.htm
            If your bearing needs replacing you could carefully grind away the spun over lip of the housing and press the original out. Then epoxy the outer case of a new bearing into the housing. The bearings are more readily available and not anywhere near as expensive as a housing and bearing assembly.
            Jim
